majazztix
(Verkaufe) Chase Bliss Audio Faves Dual Control Cable - 20cm
majazztix
ß785
majazztix hat ein neues Inserat eingestellt:
Chase Bliss Audio Faves Dual Control Cable - 20cm - Chase Bliss Audio Faves Dual Control Cable - 20cm
Verkaufe das CBA Faves Dual Control Kabel 20cm.
This cable allows you to control two Chase Bliss pedals with one Chase Bliss Faves switch.
Connect the two mono jacks with two Chase Bliss pedals and connect the stereo jack with the Faves. Press and hold two footswitches on a Chase Bliss pedal and connect the power supply. The pedal now knows that a Faves controller is connected. Perform the same procedure on the other CB pedal and you are done!Anhang anzeigen 891987
